patdman81
Jun 27, 2022Tutor
Files not moving or deleting correctly (RNDU6000)
Hi all, I'm having some issues with my NAS, where after I either copy then delete, or directly move files around using Windows File Explorer, that they still appear in the original directory and ...
- Jun 27, 2022
patdman81 wrote:I'm having some issues with my NAS, where after I either copy then delete, or directly move files around using Windows File Explorer, that they still appear in the original directory and cannot be deleted, except through the web admin interface.
Generally, I am moving from one share to another.
I've sometimes seen this, but not often enough to pursue it. Does the file eventually get deleted if you do nothing?
If you have strict sync (advanced SMB settings) turned on for the source share, you might try turning it off and see if it still happens.
I'm suggesting this because the source share where I have seen this has strict sync on (while most of my other shares have it off). Could be a red herring though, as I probably do more moves and deletes from that share..
Jun 27, 2022Guru - Experienced User
- patdman81Jun 27, 2022Tutor
The problem doesn't go away if I leave it, but I'm not sure how long I have ever "just left it alone" to really find out!
I have no patience when it comes to my files being nice and tidy 😄
I just checked and I do have strict sync enabled for that share, I'll turn it off for a week and see if things change.
If I do want to test the "just leave it alone and see if things sync" theory, do you have a recommended length of time to leave it for?
Patrick.
- StephenBJun 27, 2022Guru - Experienced User
Not really. Maybe minutes to an hour???
FWIW, I have seen that when I have a folder open on another machine, that deleting the folder will remove the files in it, but the folder itself remains until I dismiss the window on the other machine. Not sure if that is related to this symptom or not. But I am guessing that Samba is deferring the deletion for some reason - which is why you can delete it from the web interface. You'll also find it can be deleted with ssh.
OK thanks for that. It's definitely not cleaning up within hours, as sometimes I have left it 24hrs before cleaning up manually.
Let's see how the strict sync change goes.
