Jan_Buelens
Sep 22, 2014Aspirant
Filters only with rsync?
I want to set up backup jobs on an RN104 to back up 5 Windows 7 PCs. I notice to my slight consternation that filters (files & folders to be excluded) can only be specified for rsync based backup jobs...
mdgm-ntgr
Sep 22, 2014NETGEAR Employee Retired
These are options that Rsync provides. It is a protocol designed for backups. I recommend using e.g. DeltaCopy on Windows, but replacing the Rsync etc. utilities with newer ones from Cygwin.
It won't. The "remove deleted files on target" is an Rsync option.
Jan Buelens wrote:
The other thing I'm wondering: when I create a backup job from a windows source, I can't set the "remove deleted files on target" checkbox. So how will my backup job behave? Will it or won't it remove deleted files from target?
