rugene
Dec 20, 2014Guide
Final 6.2.1 update causing LAN instability/sluggishness
After upgrading to 6.2.1 on an RN314, the network adapters no longer appear in the UI. In general it looks like the network parameters were reset. I can only recover the device by letting my router ...
vandermerwe
Dec 20, 2014Master
So you can login to the GUI and see all the other tabs (System, Shares, iSCSI, etc) except the Network tab?
Or can you see the network tab but the adapters are not seen when you click on it?
Have you cleared your browser cache ?
If they are really not there then I'd do an OS reinstall ( not a factory default) using the boot menu. The OS reinstall preserves data, resets the admin password and the network settings to dhcp.
