rugene
Dec 20, 2014Guide
Final 6.2.1 update causing LAN instability/sluggishness
After upgrading to 6.2.1 on an RN314, the network adapters no longer appear in the UI. In general it looks like the network parameters were reset. I can only recover the device by letting my router ...
vandermerwe
Dec 20, 2014Master
Fair enough.
As far as I know there are currently 3 of you with this problem. We don't know what apps the other 2 have installed.
I have a 316 and 6.2.1 works perfectly. I don't have apps except LMS though.
Apps do cause problems, so it is by no means clear that this problem is related to a flaw in the OS.
