rugene
Dec 20, 2014Guide
Final 6.2.1 update causing LAN instability/sluggishness
After upgrading to 6.2.1 on an RN314, the network adapters no longer appear in the UI. In general it looks like the network parameters were reset. I can only recover the device by letting my router ...
vandermerwe
Dec 21, 2014Master
Ah yes, you can't access the GUI ( web interface).
Have you cleared your browser cache and tried a different browser?
Have you done an OS reinstall?
Do you have a backup?
You can install firmware using ssh or remote access but I'm still not confident enough to do that. There is someone on the forums who may be able to help you later.
