rugene
Dec 20, 2014Guide
Final 6.2.1 update causing LAN instability/sluggishness
After upgrading to 6.2.1 on an RN314, the network adapters no longer appear in the UI. In general it looks like the network parameters were reset. I can only recover the device by letting my router ...
nsne
Dec 21, 2014Virtuoso
Thanks to _frantic_ and dsnpvl for finding the cause and a solution.
Since I'd rather not have to mess with the terminal to have a functional, up-to-date ReadyNAS, I'd appreciate it if Netgear or the OS 6 developers could release a 6.2.1.1 or 6.2.2 update that corrects this issue.
You say this in jest, but there's a certain amount of truth to it. If this had been implemented in the beta, we could have caught it before it went to final. Instead they made untested, fundamental changes between RC3 and GM, and we — or I should say you — got to spend hours on troubleshooting.
dsnpevl wrote: Netgear should be forever in our debt for doing their work for them :)
