rugene
Dec 20, 2014Guide
Final 6.2.1 update causing LAN instability/sluggishness
After upgrading to 6.2.1 on an RN314, the network adapters no longer appear in the UI. In general it looks like the network parameters were reset. I can only recover the device by letting my router ...
Teufl_at_Readyn
Dec 22, 2014Tutor
Same Problem with me. As soon as I connect my Readynas to the network the router can't be accesses properly. Furthermore, the internet connection breaks down. As soon as I disconnect the network cable from the NAS the router-interface reacts normal and internet gets reconnected.
If I connect to the NAS, the network-interface isn't shown either.
My NAS has a static IP and some Apps installed, where Owncloud, PHPmyadmin, and VPN-softether come to mind right now.
Update: Just read the propable solution to the problem. One question there, since I have no internet conection while my readynas is online, I can't downgrade, can I? May old packages still be stored?
Otherwise I will just have to downgrade and wait for a "proper" update...
