rugene
Dec 20, 2014Guide
Final 6.2.1 update causing LAN instability/sluggishness
After upgrading to 6.2.1 on an RN314, the network adapters no longer appear in the UI. In general it looks like the network parameters were reset. I can only recover the device by letting my router ...
MarcusF
Dec 22, 2014NETGEAR Employee
Thanks both for reply.
We may still need your help because so far all works ok here.
I run a RN316 at home myself and no issue son 6.2.1, I run plex , but not bond, I don't use IPv6 either.
For looking at 1.2.6 v 1.27 connmand, that would be a bit more involved than you might think and not guaranteed solution because the issue is not widespread but I will ask dev to have a look.
_Frantic_ & dsnpevl can you send in your full system logs using info here http://kb.netgear.com/app/answers/detail/a_id/21543 with as much detail about your network as possible, router / switch models in use.
Would you both be ok to allow Netgear remote access to your systems at some pint if needed.
