rugene
Dec 20, 2014Guide
Final 6.2.1 update causing LAN instability/sluggishness
After upgrading to 6.2.1 on an RN314, the network adapters no longer appear in the UI. In general it looks like the network parameters were reset. I can only recover the device by letting my router ...
dsnpevl
Dec 22, 2014Virtuoso
OptimusPrime wrote: _Frantic_ & dsnpevl can you send in your full system logs using info here http://kb.netgear.com/app/answers/detail/a_id/21543 with as much detail about your network as possible, router / switch models in use.
Info and logs are in the mail, as requested.
OptimusPrime wrote: Would you both be ok to allow Netgear remote access to your systems at some pint if needed.
Don't drink beer myself :) I prefer wine.
OK with allowing remote access, but I'm not going to revert back to the faulty state, as I don't want any more down time on my website.
How's this for a shot in the dark? Correct me if my assumptions are wrong, because this UPnP is not my field of expertise.
- RN is using UPnP to connect to discovery server
- Router blocks UPnP
- connman 1.27-netgear1 package doesn't like this and ends up in an endless loop sending IP packages.
@_frantic_, do you have UPnP blocking on your router?
@OptimusPrime, were there changes made to UPnP handling between 1.26 and 1.27?
Not sure if this is related at all, but in regard to Wifi (direct):
[quote="Andrei Laperie @ tizen.org":2zlfzqwg]Please note that WiFi P2P is very sensitive to the wireless hardware/firmware. The combination that worked for us was Intel WP2/latest firmware/3.17 kernel. It is quite likely that other configurations might require extra work to enable P2P. [/quote:2zlfzqwg]
Could this be related to WLAN firmware / hardware in the router?
