rugene
Dec 20, 2014Guide
Final 6.2.1 update causing LAN instability/sluggishness
After upgrading to 6.2.1 on an RN314, the network adapters no longer appear in the UI. In general it looks like the network parameters were reset. I can only recover the device by letting my router ...
dsnpevl
Dec 22, 2014Virtuoso
OptimusPrime wrote: I think so far looks like fritzbox + ipv6 + new connman might be the root cause.
OK. That seems to be the common denominator. But then my friend with RN312 also has same make and model Fritz!Box without upgrade issues. And _frantic_ has a different model and does have upgrade issues. Please note that even within one make/model you can have different versions (v1, v2), a bit like GS108 also has. The 7360 I borrowed had extension v2 versus mine having no extenstion, just 7360 on the information sticker on the bottom. Still they have the same article number 2000 2536, but when I saved the setting from my router and tried to put them on the v2 version, it was not accepted as a native settings file.
I would not be supprised if you might find that this only occurs for a certain version of some chipset used in certain routers.
