rugene
Dec 20, 2014Guide
Final 6.2.1 update causing LAN instability/sluggishness
After upgrading to 6.2.1 on an RN314, the network adapters no longer appear in the UI. In general it looks like the network parameters were reset. I can only recover the device by letting my router ...
dsnpevl
Dec 22, 2014Virtuoso
@_frantic_ We are still guessing here, but the problem might only be triggered by certain models Fritz!box in combination with RN and IPv6. So moving the RN from the troublesome location to your home, means you will be using a different router and the issue might not occur any more.
The location 2 with 6360 is the site where there are problems?
Did you already test RN from location 2 at the location 1 with 7240?
Enjoy your holidays!
