rugene
Dec 20, 2014Guide
Final 6.2.1 update causing LAN instability/sluggishness
After upgrading to 6.2.1 on an RN314, the network adapters no longer appear in the UI. In general it looks like the network parameters were reset. I can only recover the device by letting my router ...
Dec 22, 2014Guru - Experienced User
Just wondering - is there a way to disable IPv6 in the router? If so, did you try playing with that setting?
