rugene
Dec 20, 2014Guide
Final 6.2.1 update causing LAN instability/sluggishness
After upgrading to 6.2.1 on an RN314, the network adapters no longer appear in the UI. In general it looks like the network parameters were reset. I can only recover the device by letting my router ...
dsnpevl
Dec 22, 2014Virtuoso
StephenB wrote: Just wondering - is there a way to disable IPv6 in the router? If so, did you try playing with that setting?
There is a way to switch off IPv6 in mine (Fritz!box 7360) and I would expect in most routers. Didn't think of that during testing though. And not going to try it any more now that I finally have a workaround in place and my website is online again. To be honest, I'm quite scared to do a reboot in fear of the issue reappearing.
