rugene
Dec 20, 2014Guide
Final 6.2.1 update causing LAN instability/sluggishness
After upgrading to 6.2.1 on an RN314, the network adapters no longer appear in the UI. In general it looks like the network parameters were reset. I can only recover the device by letting my router ...
Dec 22, 2014Guru - Experienced User
Software can and is ported to more than one platform. Platforms can often run more than one software stack.
dsnpevl wrote:
StephenB wrote: I agree that a list of routers could be helpful for them. I don't think this is likely to have much to do with the chipset. More likely it relates to the IP software stack in the router.
Don't IP protocol stacks run inside chipsets?
So a software bug can affect multiple routers using different hardware chipset, and there might be other routers using the same chipset that have no problem at all.
