rugene
Dec 20, 2014Guide
Final 6.2.1 update causing LAN instability/sluggishness
After upgrading to 6.2.1 on an RN314, the network adapters no longer appear in the UI. In general it looks like the network parameters were reset. I can only recover the device by letting my router ...
Jack_A_Lope
Dec 22, 2014Aspirant
This may be a bit off topic, but I believe it is related to the 6.2.1 update. Hope it helps in finding a solution.
After my update I did not seem to have a problem. My problem occurred after installing then uninstalling the application 'Contacts and Calendars Server'. I can now no longer log into the admin web page at all. When I try to get to it via a browser, it says it does not connect. There is no login window that pops up, nothing. I have no access to controlling the RN104 any more. I can see my files on the various shares but but I cannot access the admin interface at all.
Again, I apologize if this is off topic and should be somewhere else. I'm a newb to forum posting. Hope this helps in the list of symptoms and a finding a solution. :oops:
EDIT: Optimus prime moved this the new thread http://www.readynas.com/forum/viewtopic.php?f=65&t=79158
EDIT: Thanks Optimus Prime. -- Jack_A_Lope :)
