rugene
Dec 20, 2014Guide
Final 6.2.1 update causing LAN instability/sluggishness
After upgrading to 6.2.1 on an RN314, the network adapters no longer appear in the UI. In general it looks like the network parameters were reset. I can only recover the device by letting my router ...
mdgm-ntgr
Dec 22, 2014NETGEAR Employee Retired
6.2.2-RC1 is now available and has connman downgraded back to 1.26: viewtopic.php?f=154&t=78866
If some of you are able to try 6.2.2-RC1 that would be appreciated.
If you are currently experiencing the issue, follow these steps:
1. Unplug ReadyNAS
2. Disable IPv6 DHCP on the router
3. Reconnect ReadyNAS
4. Install 6.2.2-RC1
5. Enable IPv6 on router
6. Reboot the ReadyNAS once more.
1. Unplug ReadyNAS
