rugene
Dec 20, 2014Guide
Final 6.2.1 update causing LAN instability/sluggishness
After upgrading to 6.2.1 on an RN314, the network adapters no longer appear in the UI. In general it looks like the network parameters were reset. I can only recover the device by letting my router ...
MarcusF
Dec 23, 2014NETGEAR Employee
For the IPv6 address showing
That is known as link local and exists the moment IPv6 is enabled
The packet trace if can take a small window (not huge trace) and send in us same process as send logs would help see what is generating the packets and if really is same issue.
The TX / RX size seems large if you were only rebooted short time.
For example unplug and replug cable does not rest the counter.
Going to auto shutdown and waking up may not reset and you would need a full reboot cycle I think, but must confirm.
Could you try and OS reinstall when on 6.2.2 RC1, this will reset network settings and admin password.
inet6 addr: XXXX::2ac6:8eff:fe34:681/64 Scope:Link
