rugene
Dec 20, 2014Guide
Final 6.2.1 update causing LAN instability/sluggishness
After upgrading to 6.2.1 on an RN314, the network adapters no longer appear in the UI. In general it looks like the network parameters were reset. I can only recover the device by letting my router ...
MarcusF
Dec 23, 2014NETGEAR Employee
Jijones wrote: I cannot access my UI page, how do I install the update? I tried reinstalling the os no luck.
if is same problem as this thread what you need to do first is disable IPv6 in your network and reboot the ReadyNAS.
If it not related to Ipv6 and symptoms detailed above can you start a new thread thank you
