rugene
Dec 20, 2014Guide
Final 6.2.1 update causing LAN instability/sluggishness
After upgrading to 6.2.1 on an RN314, the network adapters no longer appear in the UI. In general it looks like the network parameters were reset. I can only recover the device by letting my router ...
Skywalker
Dec 23, 2014NETGEAR Expert
If you connect the network cable directly from the NAS to a PC, both devices should end up with link-local addresses, and you should be able to discover and connect to the NAS to do the upgrade.
