rugene
Dec 20, 2014Guide
Final 6.2.1 update causing LAN instability/sluggishness
After upgrading to 6.2.1 on an RN314, the network adapters no longer appear in the UI. In general it looks like the network parameters were reset. I can only recover the device by letting my router ...
doctorv1
Dec 23, 2014Aspirant
Hello,
I've been following this issue, but didn't speak up since I didn't have much to contribute and I'm using the firmware on unsupported hardware (ReadyNAS Pro 6). After upgrading to 6.2.1 I was having the same LAN instability and router crash issues. I tested the fix and can confirm that when I disabled IP6 on my router (FritxBox 7390) the LAN issues went away. I then installed the 6.2.2RC1 firmware, re-enabled IP6 on the router and the problem did not come back. So far the fix seems to work.
I was lucky in that I wanted to factory reset the NAS anyway before doing some final configuration changes.
Chuck
Chuck
