rugene
Dec 20, 2014Guide
Final 6.2.1 update causing LAN instability/sluggishness
After upgrading to 6.2.1 on an RN314, the network adapters no longer appear in the UI. In general it looks like the network parameters were reset. I can only recover the device by letting my router ...
Mar 06, 2015Guru - Experienced User
Is IPv6 disabled also on the router? Does anything change if you enable IPv6?
There were issues with flooding in 6.2.1, but 6.2.2 had the fix.
Unfortunately, this kind of flood sometimes happens when the NAS has been hacked. So you might need to contact support (even if they charge you).
