rugene
Dec 20, 2014Guide
Final 6.2.1 update causing LAN instability/sluggishness
After upgrading to 6.2.1 on an RN314, the network adapters no longer appear in the UI. In general it looks like the network parameters were reset. I can only recover the device by letting my router ...
Mar 06, 2015Guru - Experienced User
You shouldn't be seeing the flood of traffic, and you haven't really identified the cause.
Though it is good that the issue doesn't occur with the old router - seems to me that makes it much less likely that the NAS is compromised.
Do you have a static IP address assigned?
