mdgm-ntgr
Oct 11, 2011NETGEAR Employee Retired
Firefly incompatible with iTunes 10.5
I updated to iTunes 10.5 today. Unfortunately whilst I can see my Firefly libraries as shared libraries in iTunes I can no longer connect to them.
mdgm-ntgr
Oct 20, 2011NETGEAR Employee Retired
thetalm wrote:
Anyway, a contribute from Apple Community Forums (posted by Deledrius), from the thread about the same issue:
The problem (for any server software based on mt-daapd) is that iTunes now seems to require the SupportsUpdate field in the initial server-info handshake, which mt-daapd doesn't supply. Adding it to mt-daapd (even with a value of False) works with iTunes 10.5 fine
Do you have a link to this thread? Does Deledrius's post specifically refer to iTunes 10.5 or are you looking at an old thread referring to a compatibility issue that developed last year and was addressed by Apple?
