mdgm-ntgr
Oct 11, 2011NETGEAR Employee Retired
Firefly incompatible with iTunes 10.5
I updated to iTunes 10.5 today. Unfortunately whilst I can see my Firefly libraries as shared libraries in iTunes I can no longer connect to them.
hibernian56
Nov 09, 2011Aspirant
mdgm wrote: Did you install one of the earlier versions of the update? If so, that would explain why you have problems. The current version of the add-on is 1.0.3. I have a suggestion here: http://www.readynas.com/forum/viewtopic.php?p=328221#p328221 or here: http://www.readynas.com/forum/viewtopic.php?f=22&t=58468&p=328951#p328951
Thanks mdgm,
I just ordered an extra 2tb drive, going to do a backup, update and factory default when it arrives. I will wait until then to clean things up, this will give me a few days to tidy up the music meta data anyway.
How do I access the system folders to manually configure?
