mdgm-ntgr
Oct 11, 2011NETGEAR Employee Retired
Firefly incompatible with iTunes 10.5
I updated to iTunes 10.5 today. Unfortunately whilst I can see my Firefly libraries as shared libraries in iTunes I can no longer connect to them.
mdgm-ntgr
Jan 26, 2012NETGEAR Employee Retired
Running 4.1.8 firmware indicates you have a Duo v1 not a Duo v2 (see How to tell whether I have a Duo v1 or Duo v2 or NV+ v1 or NV+ v2
Looks like you're not using the default path to store your Music. If using the Music folder on the media share it would have discovered your Music automatically.
Firefly has its limitations. It does not share Album artwork. As for getting iTunes to connect to the server when iTunes launches, I don't know if that's possible.
