BJB
Dec 31, 2017Aspirant
Firmware 6.61 to 6.91 on RN104?
Greetings. I have read the release notes and realize that from a technical standpoint I am okay moving from 6.61 to 6.91 on my RN104. However I have been through firmware issues in the past and jus...
- Jan 01, 2018
There are a few fixes and updates from 6.6.1 since few firmware have been release prior to 6.9.1 like SMB support and NIC updates etc. It shouldn't cause any hiccups but that is why I also recommend doing a Factory reset assuming that it has not been done due to your current firmware. 6.6.1.
Again backing up data before doing any change on the system is always a good practice.
Regards
Marc_V
Jan 01, 2018NETGEAR Employee Retired
Hi BJB
From the release notes
- ReadyNAS 102, 104, and 2120 must not be updated directly to 6.9.x from 6.3.x or older firmware. They must first be updated to either 6.2.5 or 6.3.5 then to 6.5.2 and then onto 6.9.x.
Since you are on 6.6.1 it is fine to go upgrade directly to 6.9.1, I would still recommend backing up your files as a safety precaution and if you have all your files safely backed up I would also recommend doing a factory reset to have a fresh OS 6.9.1 implemented on you RN104.
Hope this helps!
Regards
BJB
Jan 01, 2018Aspirant
Marc,
Thanks. I did see those release notes as I always read them, I just wondered if out in the user or support community there were hiccups to be aware of.
Or if this was a major or minor upgrade.
Thanks,
BJB
Thanks,
BJB
- Marc_VJan 01, 2018NETGEAR Employee Retired
Regards
