InteXX
Dec 07, 2025Luminary
Firmware Downloads
FYI here's a little script that downloads all available firmware versions starting with v6.0.0. It'll be good to keep them on hand for the day that they go away online. Unfortunately, however, so...
portalman
Dec 07, 2025Aspirant
What script is that? Powershell or something?
Shame it's not linux so you could run on the readynas!
- InteXXDec 07, 2025Luminary
Oops... I should have said so. Yes, it's PowerShell.
Sure, you can run PowerShell on Linux. The latest version (v7) is cross-platform.
Here's the installation:
sudo apt update
sudo apt install -y curl gnupg apt-transport-https
curl https://packages.microsoft.com/keys/microsoft.asc | sudo apt-key add -
sudo sh -c 'echo "deb [arch=$(dpkg --print-architecture)] https://packages.microsoft.com/repos/microsoft-debian-$(. /etc/os-release; echo $VERSION_CODENAME)-prod $(. /etc/os-release; echo $VERSION_CODENAME) main" > /etc/apt/sources.list.d/microsoft.list'
sudo apt update
sudo apt install -y powershellTo run it:
pwsh
