Graduate
Apr 26, 2020Follower
firmware update failure
Hi, I am trying to update the firmware on my ReadyNAS 104 storage server. Unfortuntely neither the automatic or manual methods woould not work. I am curently on 6.9.4 Hotfix 1 version and tryin...
Apr 27, 2020Guru - Experienced User
How does the update fail?
How full is your root partition?
What apps do you have installed?
You can download the log zip file, and look in volume.log to see the root partition fullness.
=== df -h === Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 4.0G 1002M 2.8G 27% /
The section above has this info (it's the /dev/md0 line).
