Gandalf913's avatar
Gandalf913
First Hard Drive expantion question
Hi all.   I am hoping this is a nice a simple and easy question. I am running a ReadyNAS 104 and have updated to 6.4.2 Currently have 2x 2TB drives   I am about to fill the two remaining bays w...
  • StephenB's avatar
    May 09, 2016
    It will process them one at a time anyway, so I suggest inserting one, waiting for it to complete, and then adding the second.  Then if something were to go wrong, you'd know exactly where it was.
    Hot-insert (NAS running).  The disks should be unformatted.
    I think it will be around 16 hours per drive (though the first one could be faster than the second).
ProSupport for Business
