MathemAddicts
Jan 11, 2016Tutor
First time install of ReadyNAS 316 and having a couple issues
I just received my ReadyNAS 316 and two 6 TB Western Digital Red drives. I followed the installation guide perfectly so far, but I am stumped at the moment. I turned on the unit for the first time ...
mdgm-ntgr
Jan 11, 2016NETGEAR Employee Retired
1. Syncing the disks sector by sector to setup the RAID.
2. Pressing the O.K. button is to confirm that you have physical access to the box. Once that is clicked the ReadyCLOUD account should be linked with your box.
- MathemAddictsJan 11, 2016Tutor
Thank you for your reply. So that takes care of #1, but #2 is an issue. The OK button on the front panel of my 316 is lit up (light purple) along with the direction arrow/ring around it and the NETGEAR logo; however, when I touch "OK" nothing happens (the LED on the ReadyNAS 316 says "Touch OK", but no matter how often I touch it, nothing happens). Am I missing something fundamental here?
I have created a video to show exactly what I am talking about. Here is a link to it.
That link will take a few moments to load... sorry.
- mdgm-ntgrJan 11, 2016NETGEAR Employee Retired
Which firmware is the unit running?
Perhaps try again once the sync completes?- MathemAddictsJan 12, 2016Tutor
Well, I never got the front panel to work, but the kind folks in tech support gave me an alternative pathway to getting things setup. I just downloaded and used RAIDar (which was nowhere in the instructions).
