MathemAddicts
Jan 11, 2016Tutor
First time install of ReadyNAS 316 and having a couple issues
I just received my ReadyNAS 316 and two 6 TB Western Digital Red drives. I followed the installation guide perfectly so far, but I am stumped at the moment. I turned on the unit for the first time ...
MathemAddicts
Jan 11, 2016Tutor
That link will take a few moments to load... sorry.
mdgm-ntgr
Jan 11, 2016NETGEAR Employee Retired
Which firmware is the unit running?
Perhaps try again once the sync completes?
- MathemAddictsJan 12, 2016Tutor
Well, I never got the front panel to work, but the kind folks in tech support gave me an alternative pathway to getting things setup. I just downloaded and used RAIDar (which was nowhere in the instructions).
- JennCJan 12, 2016NETGEAR Employee Retired
Hello MathemAddicts,
Did you mentioned the front panel issue you have to the support person? Because if that is a hardware problem then it needs to be addressed too.
I did. However, it now works. I am not certain what hocus pocus occured, but it's all fixed now!
