fastfwd
Sep 02, 2013Virtuoso
Flash Auto Copy
Pro Pioneer running OS 4.2.24. In Frontview:Volumes:USB Storage, there's an option to automatically copy the contents of a connected USB Flash device to a share. Unfortunately, the automatic copy fu...
chirpa
Sep 02, 2013Luminary
Will the connection be on a regular interval? To schedule a backup job and have it run periodically when the drive would be there?
If not, there are ways to add scripts to perform a custom job when connecting the drive. I don't have a ReadyNAS handy to check the paths, but should be somewhere around /etc/hotplug.d/usbstorage.d/ directory. If scripts are in there, they would run on connection. There are variables to trigger path and volume name and such. I used this setup to make encrypted volumes back in the day with auto key management. I'll try and dig up those old scripts if possible.
