hoptop
May 05, 2021Aspirant
flashing power and act 3 time
after a power lost now when trying to start the nas up all i get is the dics 1 light flash 3 time slow then all the light flash 3 time fast power act and 1&2 and do not show in raiddar
- May 08, 2021
i think it sorted now toke out the battery on bord hold down the reset button for 30 sec put it back in now back up and running
but thanks for the help
hoptop
it does only say readynas duo not do not have a backup :smileysad:
May 05, 2021Guru - Experienced User
Ok.
I'd start by connecting Disk 1 to a Windows PC (either with SATA or a USB adapter/dock) and then see if R-linux for Windows can find the files. https://www.r-studio.com/free-linux-recovery/ If it does, then try offloading the data. I suggest labeling the disks as you remove them, so you don't lose track of their slots.
While the disk is out, then try booting with disk 2 in slot 2 (leaving slot 1 empty), and see if that gives the same error code.
- hoptopMay 08, 2021Aspirant
try taking one disk out still the same then try taking all the disk out and put a new one in and still the same and the reset buton do not do anythink
- StephenBMay 08, 2021Guru - Experienced User
hoptop wrote:
taking all the disk out and put a new one in and still the same and the reset buton do not do anything
If the new disk was blank, the NAS would do a factory install. There is a 10 minute lag before that starts, so if you didn't wait long enough you wouldn't see any disk activity. If the disk was formatted, the NAS might also have detected it was not bootable - and then it would have given you a corrupt root error.
Either way, the next step is to try R-linux for Windows, and see if it can find the files on the disks so you can copy them off.
