Campus
Feb 22, 2019Luminary
Flex-Raid not using Global Spare
I am running two Flex-RAID volumes where in one of them one of drives died. I replaced the dead one with a (used) disk and used the Web UI to destroy the existing data on that disk, formatted it and ...
Feb 22, 2019Guru - Experienced User
Try selecting the volume, then the disk. There should be an option to add the disk to the volume.
Campus
If I do this, I get the attached view. Where do I have to click?
- StephenBFeb 22, 2019Guru - Experienced User
Can you click on "add parity"?
- CampusFeb 22, 2019Luminary
No, except for "Cancel" all buttons on the left are disabled.
I think selecting global spare was a mistake. But they changed flexraid a few releases ago, and I'm not currently using it.
Was the failed disk also 4 TB?
