j0hanSE
Jun 09, 2013Aspirant
Flex-Raid
Hi, just installed a second HDD to my Ultra 2. I wondering if its possible that the /media/video/ folder is both disk 1 + disk 2 (C+D) atm its just disc 1 (C) it says on the sharelist. Or how sh...
Jun 10, 2013Guru - Experienced User
Ok.
Each folder is in only one volume (C or D). FlexRaid is completely manual, so you will need to copy folders onto volume D in order to start using the second disk.
For instance, rename a share on volume C, and then create a new share with the original name on volume D. Create a frontview backup job to do the copying. After it completes, delete the old share on volume C.
