Blanker-2
Apr 07, 2017Apprentice
Flexraid Calculator
I am trying to understand the usable space with the flexraid format amongst disks of different capacities. The online calculator is missing certain disks like 5TB and 650TB, etc. Any documentation ...
- Apr 07, 2017
Blanker-2 wrote:
Any documentation I may have missed?
The software manual ( http://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf ) does talk about FlexRaid expansion - see pages 35-36.
Blanker-2 wrote:
It seems as though the flexraid format needs to have disks of the same size. So a flexraid (RAID5) array of two 2TB diks and two 5TB disks will yeild a usable volume of 6TB (esentially wasting 3TB of each 5TB disk, and reserving one 2TB disk for redundancy)?
That is what the manual says. One small correction - the parity blocks that create redundancy are evenly spread across all the disks. But that change your capacity assessment. Anyway, you understand the underlying principle, so you can compute capacity w/o the calculator.
There could be some special cases where unequal disks can be used - I think jak0lantash posted the results of a lot of expansion experiments he did some months ago.
With that particular combination of disks, you get 7 TB by creating a 2x2TB RAID-1 volume and a 2x5TB RAID-1 volume. X-RAID of course gives you 9 TB. The rule for X-RAID single redundancy is "sum the disks and subtract the largest".
Apr 07, 2017Guru - Experienced User
