john_es
Oct 14, 2013Aspirant
FlexRaid2 - Expanding disks
I have a readynas pro 6. It has 6, 3TB drives, for a total of 13TB of usable space out of 18TB. I want to start migrating to 4TB drives, but not all at once. 1.) If I put 2, 4TB drives in there...
mdgm-ntgr
Oct 14, 2013NETGEAR Employee Retired
You would get about 0.9TB of expansion.
Recall the two expansion limitations:
1. 8TB online over the life of the volume i.e. If when you last did a factory default the volume capacity was say 4.8TB you can't expand past 12.8TB.
2. You cannot expand a volume past 16TB. You have to do a factory default with the disks in place.
