jimbo123
Dec 23, 2014Aspirant
Following OS6.2.1 update LAN / WAN issues
I had thought that the problem as discussed - http://www.readynas.com/forum/viewtopic.php?f=65&t=79118&sid=0b9830fdba963be84363284497f3397d&start=75 was the problem however this appears not to be the ...
jimbo123
Dec 24, 2014Aspirant
mdgm wrote: Do you have any ports forwarded to your NAS?
No ports forwarded and no UPnP enabled on router. I forget to add to the other forum I have no other apps running apart from Anti-Virus Plus (Checked this in htop as well - No sign of any other installed app running).
chirpa wrote: You've likely got a rootkit installed on your NAS.
Given the likely implications if there is a rootkit installed. Would anyone moderator wise want to take a look at it before I wipe the NAS?
