jimbo123
Dec 23, 2014Aspirant
Following OS6.2.1 update LAN / WAN issues
I had thought that the problem as discussed - http://www.readynas.com/forum/viewtopic.php?f=65&t=79118&sid=0b9830fdba963be84363284497f3397d&start=75 was the problem however this appears not to be the ...
jimbo123
Dec 24, 2014Aspirant
mdgm wrote: The /boot directory should be empty.
So delete the files? I am really not sure on the next step, if it is rootkit then a factory reset would seem the best option but if there is another cause I would like to get to the bottom of that.
