jimbo123
Dec 23, 2014Aspirant
Following OS6.2.1 update LAN / WAN issues
I had thought that the problem as discussed - http://www.readynas.com/forum/viewtopic.php?f=65&t=79118&sid=0b9830fdba963be84363284497f3397d&start=75 was the problem however this appears not to be the ...
jimbo123
Dec 24, 2014Aspirant
mdgm wrote: Rootkits can be very difficult to remove, so yes a factory default would probably be best.
Okay thank you for the help in the matter, I will get to performing the factory reset.
