Luterin's avatar
Luterin
Forcing a resync? How to, and is it needed?
I am starting to wonder if my ReadyNAS 104 (v6.4.1) is doing its monthly resyncing, as most mdadm bases NASes do, since I am encountering a bit of read errors in dmesg, but they can ofcourse be relat...
  • mdgm-ntgr's avatar
    Jan 24, 2016
    We disabled the default automatic monthly mdadm resync, but instead have added the ability for you to schedule scrubbing on the schedule you prefer.
    Go to System > Volumes, click the Settings Wheel for your volume and you should see a Volume Schedule option.
    Best to schedule volume maintenance to run when the NAS will be used lightly. Weekly defrag and balance would be recommended. Scrubbing should not be done too regularly. Certainly not any more often than monthly. Personally I'd do it about every 3 months or so.
    No amount of volume maintenance is a replacement for backing up your data. If the NAS holds the primary copy of important data then you should backup that data.
    Volume maintenance can be used to keep your NAS perfoming optimally and help reduce the likelihood of needing to do a full restore from backup, but it does not replace the need to backup.
    Welcome to the Community!
ProSupport for Business
