Mac_Cash
May 01, 2016Aspirant
Formatting/Reformatting NAS 102 as JBOD
I have a ReadyNAS DUO that I use for critical redundant storage. I also have a NAS 102. I want to use this for non-critical network storage (ripped mp3's, temporary copied video's and images, etc). I...
Mac_Cash
already moving the data to alternative storage.
already uninstalled the aps
(b) switch to flexraid on the volume page
While both disks are still in the housing???
On the 'volumns' page the the X-RAID button doesn't have a green line on it right now, but under the drive icon in the middle of the page it says RAID (RAID 1).
I assume I switch to Flex-Raid by clicking the X-RAID button???
(c) destroy the current data volume
?destroy? Once I complete (b) are you saying I select the 'new volume' button and
it will prompt me to create a new volume(s) and one option will be JBOD?
or
is this something that get prompted when I click the X-RAID button???
(d) select the first disk, and create a jbod data volume called "data"
I click on the disk image in the middle of the screen??? and
can I name it something else, or is 'data' a reserved/required name???
(e) select the second disk and create a second jbod data volume.
and do it once more for the second disk
Do I also have to name that one 'data'???
(f) and (g) I understand
I'm usually very good with tech, but the interface for this device is, in my opinion, not very intitutive.
Or maybe I just don't speak 'disk storage' very well...
Thank you,
Mike
BrianL2
May 01, 2016NETGEAR Employee Retired
Hi Mac_Cash,
Welcome to the community!
You can just destroy the volume then both disks will be available (in gray color) for new volume creation. Select the 1st disk (a green bar will show up when its selected) then create a new volume in JBOD format name it anything you want like 'data' and once its created, you can proceed doing the same on the 2nd disk (volume name should be different).
Kind regards,
BrianL
NETGEAR Community Team
