PatrickJ
May 17, 2016Aspirant
From NV+ to 316
Hi! I have had a working NV+ for many years and just upgraded to a 316 that I bought on eBay. I have 4 2TB drives at 46% capacity of 5.44 TB in my NV+ (with very little use on them). I would like t...
- May 18, 2016
PatrickJ wrote:
Hi StephenB,
Thanks for replying! What do you think about buying a 3TB disk, doing a full backup from the NV+ to the 3TB in the 316 and then vertically expanding my array using the disks in the NV+?
That won't work with XRAID. Once you have the 3 TB volume, you can't expand it unless you add 3 TB or larger disks.
The external drive is probably a better bet. You will need to do that backup through a PC, since the NV+ won't recognize a 3 TB drive (either USB or internal).
PatrickJ
May 18, 2016Aspirant
Hi StephenB,
Thanks for replying! What do you think about buying a 3TB disk, doing a full backup from the NV+ to the 3TB in the 316 and then vertically expanding my array using the disks in the NV+? I'll have some unused space in the end (~1TB), but it seems easy. What do you think? Or am I better off backing up to the 3TB externally and starting the array off fresh?
Thanks again!
Patrick
May 18, 2016Guru - Experienced User
PatrickJ wrote:
Hi StephenB,
- PatrickJMay 18, 2016Aspirant
Awesome! Thanks for the great advice, StephenB. Can I later add the 3TB drive to the 2 TB disk array if I want?
That helps me a lot, I really appreciate it!
Best,
Patrick
- StephenBMay 18, 2016Guru - Experienced User
Yes. You can either add it, or replace a 2 TB drive with a 3 TB drive. As you know, you'll waste 1 TB of space on the drive until you add a second one.
I suggest NAS-purposed drives (WDC Red or Seagate VN) or an enterprise drive. I recommend avoiding the Seagate DM.
Again, great advice. Thanks very much.
Best,
Patrick
- Jun 06, 2017Retired_Member
