Nienkerk
Jun 14, 2016Aspirant
Front Panel Shows error "kmem_cache_alloc+5c" - #27013537
Hello!
I have just upgraded to the last disk and it was on 96% last night of several days of resynch. When I woke up this morning I couldnät connect so I had a look at the box. The display show...
Nienkerk
Jun 15, 2016Aspirant
4 disk (4tb WD Red PRO)
I think i can get full backup of the data.
I fint know what RAIDar is
On the display on the box
I got the box running yesterday and turned all the apps off. I reinstalled and rebooted the device. Then I let it continue with the reshape of data on the last disk. Got a error message this morning again "mv_xor_status+88". I couldn't connect to it so I pulled the plug again. What do i do now?
- StephenBJun 15, 2016Guru - Experienced User
Nienkerk wrote:
I fint know what RAIDar isRAIDar is a PC app that can make it easier to manage your NAS. You'll find it here: http://kb.netgear.com/app/answers/detail/a_id/20684/~/readynas-downloads#raidar
- NienkerkJun 15, 2016Aspirant
Do you think this problem has to do with the HDDs or the OS?
Can RAIDar help me?
RAIDar can often give you some information on the NAS status (and allow you to download the logs) even if the web ui is not responsive. It won't fix anything, but it might help get the relevant info.
Have you looked at the disk health? Try to download the log zipfile while the system is running, and look in smart_history.log.
