Nienkerk
Jun 14, 2016Aspirant
Front Panel Shows error "kmem_cache_alloc+5c" - #27013537
Hello!
I have just upgraded to the last disk and it was on 96% last night of several days of resynch. When I woke up this morning I couldnät connect so I had a look at the box. The display show...
Jun 15, 2016Guru - Experienced User
Nienkerk wrote:
I fint know what RAIDar is
RAIDar is a PC app that can make it easier to manage your NAS. You'll find it here: http://kb.netgear.com/app/answers/detail/a_id/20684/~/readynas-downloads#raidar
Nienkerk
Jun 15, 2016Aspirant
Do you think this problem has to do with the HDDs or the OS?
Can RAIDar help me?
- StephenBJun 15, 2016Guru - Experienced User
RAIDar can often give you some information on the NAS status (and allow you to download the logs) even if the web ui is not responsive. It won't fix anything, but it might help get the relevant info.
Have you looked at the disk health? Try to download the log zipfile while the system is running, and look in smart_history.log.
- NienkerkJun 15, 2016Aspirant
I looked in the smart log and found this
time model serial realloc_sect realloc_evnt spin_retry_cnt ioedc cmd_timeouts pending_sect uncorrectable_err ata_errors
2013-04-23 16:20:40 TOSHIBA DT01ACA100 33453RGPS 0 0 0 -1 -1 0 0 0
2013-04-23 16:20:40 TOSHIBA DT01ACA100 334489ENS 0 0 0 -1 -1 0 0 0
2016-06-10 16:45:16 WDC WD4001FFSX-68JNU WD-WMC5D0D2N1W3 0 0 0 -1 -1 0 0 0
2016-06-10 19:06:28 WDC WD4001FFSX-68JNU WD-WCC5D6RZUEL7 0 0 0 -1 -1 0 0 0
2016-06-11 11:19:05 WDC WD4001FFSX-68JNU WD-WCC131AXFYZD 0 0 0 -1 -1 0 0 0
2016-06-13 06:39:57 WDC WD4001FFSX-68JNU WD-WMC130D0ZD5C 0 0 0 -1 -1 0 0 0Looks like nothing but its not my first language if you know what I mean :)
- Retired_MemberJun 15, 2016
That means no error seen by readynasd (the service running part of readynas OS). If there were errors here, that would have brought some explanation. As there isn't any, the answer is elsewhere.
You should double check in disk_info.log that sdb is actually clean.
