jwishnie
Nov 16, 2014Aspirant
Frontview missing images / JS after USB Recover
ReadyNAS NV+ Just stopped accepting SSH and HTTP connections. Performed USB Restore with 4.1.14 image from here: http://www.readynas.com/download/suppor ... 4.1.14.img Frontview comes up wit...
mdgm-ntgr
Nov 16, 2014NETGEAR Employee Retired
Well you could remove that. There's likely other things as well that are filling it up, so keep looking. Usage of the OS partition should be well below 1GB.
Then after the OS Re-install install this Sparc add-on: http://www.readynas.com/forum/viewtopic.php?p=392371#p392371
Installing this add-on once will get the ReadyDLNA cache to be stored on the data volume instead of the OS partition. This would be a help as your OS partition would be less likely to fill up. Installing the Toggle add-on a second time would change it back to using the OS partition (not recommended).
