jugalbandi
Jul 02, 2015Aspirant
frontview not accessible...made stupid mistake - please help
Hi, I made a stupid and potentially very costly mistake. I logged in as root. Went into an attached USB drive that I use as backup of the NAS shares. Backup was old and I had substantially change...
mdgm-ntgr
Jul 09, 2015NETGEAR Employee Retired
If restoring your config backup fails you can always do another factory reset and reconfigure the system manually, but the config backup assuming it was taken before your mistake to attempt to remove everything should work.
