zorglub1
Dec 03, 2014Aspirant
Frontview not opening, missing apachectl
Hello, I had a power outage. Then the filesystem check would not complete. I ended up having to reboot my ReadyNAS NV+ several times until it successfully completed. When the ReadyNAS finally bo...
mdgm-ntgr
Dec 04, 2014NETGEAR Employee Retired
There is an OS Re-install boot menu option, but as you found installing 4.1.14 over the top of itself via Frontview also works.
