g262
Dec 08, 2012Aspirant
Frontview USB Backup Not Working!
Losing patience here... Plugged a brand new Silicon Power 1TB USB 3.0 drive into my new NV+ v2 and configured a simple backup drive per instructions, and was getting AppleDouble filename errors whi...
HERBIEO
Not being a mac user i cant help you there but i am sure someone on the forum will see this post and give you some advice how you can do this, unless you can get access to a windows or linux system to format your USB drive.
Edit: i think ext file system as less problems with invalid characters in file names so ext may be the best option,
i know with FAT32 and NTFS file and directory names may not contain the characters " / \ * ? < > | :
