jnorris441
Jan 03, 2014Aspirant
Frozen NAS, RAIDar says "not present"
My oldest unit is a RND4000. All the lights are green (although the status screen at the bottom stays lit). http://imgur.com/ZIpjmzD&XlRsnOS However when you look at it in RAIDar, everything...
bom
Jan 07, 2014Aspirant
Did you solve your problem? I am asking as I have a similar, if not the same, problem as of yesterday. The front panel of my ReadyNAS NV+ looks exactly the same as the picture you posted. And, when I look at the NAS with RAIDar, I have the same status ('Not present'). The only difference is that I am on firmware version 4.01c1-p1.
Problems started when I accessed one of the mounted share drives from a windows machine. The window for the share drive open and then disappeared. After that I could not access the shares from windows explorer or via a browser (http://192.168.1.150/admin). I shut off the NAS and turned it back on. The NAS was working hard and I received a status email entitled 'RAID event detected (rn1)' with the following in the body of the email.
RAID sync started on volume C.
[Mon Jan 6 20:39:28 CST 2014]
Later the operation completed and I received an email entitled 'RAID event detected (rn1)' with the following content in the body of the email.
RAID sync finished on volume C. The volume is now fully redundant.
[Mon Jan 6 23:40:27 CST 2014]
After I could still not access the NAS. The front panel remained the same and the status on RAIDar remained the same. Shut down the NAS and re-started, no change. (Note that the LCD on the front panel continued to display its 'Shutting down...' message even after the NAS shut down.)
Any suggestions?
Any suggestions?
